Re: Engine not starting, carb backfires!
[Re: B300 VanDanage]
#3003594
01/09/22 08:56 PM
01/09/22 08:56 PM
Posts: 10,863 Freeport IL USA
poorboy
Freeport IL USA
If the drive shaft fell out, I would be concerned that it is not bent. Doesn't take much of a dent in a driveshaft to mess it up bad. If there are no dents and the drive shaft is still balanced, which way the driveshaft is connected to the rear axle shouldn't matter. On the rare occasions it does, simply turning the driveshaft 180 degrees may correct the out of balance. I wouldn't expect much help with turning the shaft 180 degrees, but it might help.
You should be able to jack up the rear end on a level surface and get both wheels off the ground with jack stands under the rear axle. Its important the weight of the van is on the axle, and the axle is on the jack stands, and the tires clear the ground by a couple of inches. Start the van and put it in gear. At an idle, while in gear (a helper would be great but it can be done alone), look to be sure the driveshaft is spinning true and not wobbling at the center or either end. If its wobbling, it needs to be rebalanced, or the U joints replaced at the least, but the drive shaft probably needs to be replaced because I suspect its bent. You can not straighten a bent driveshaft. When you have completed the test, shut the van off in gear and let it coast to a stop, then put it in park after the tires have stopped spinning and you are ready to set the van back on its wheels.
If it spins OK at an idle, you can bring it up slowly to about 45 mph, anything out of balance should show up, you will feel the vibration up through the seat and the van. If the vibration gets real bad at any point, stop the test. Be aware that an out of balance vibration could be the tires and wheels, or the driveshaft. By theory, you should be able to bring the speed all the way up to the driving speed you drive, but I simply don't trust jack stands that much, should the stands fail, and the tires hit the ground, the van will take off at whatever speed the speedometer says its going. Not a pretty picture.
Obviously, a bad vibration needs to be corrected before you drive it, but a very minor vibration may be simple tire balance and can be corrected when you have time. I'd start with the tires before I'd try anything with the driveshaft balance. Also be aware that a vibration you feel with the van on jack stands may or may not show up when driving, and sometimes a vibration while driving won't show up with the wheels off the ground. Tire balance or tire problems can often show up like that. Usually a driveshaft balance shows up consistently. Gene
Entire Thread
B300 VanDanage
11/13/21 03:49 PM
stumpy
11/13/21 04:21 PM
John_Kunkel
11/13/21 08:23 PM
Powerflow
11/13/21 10:32 PM
B300 VanDanage
11/14/21 11:47 PM
Powerflow
11/15/21 01:26 AM
B300 VanDanage
11/15/21 01:48 AM
B300 VanDanage
11/14/21 02:04 PM
GODSCOUNTRY340
11/14/21 02:28 PM
B300 VanDanage
11/14/21 11:39 PM
Sniper
11/15/21 12:03 AM
poorboy
11/15/21 01:02 AM
B300 VanDanage
11/15/21 01:33 AM
RustyDuster
11/17/21 05:15 AM
B300 VanDanage
11/15/21 01:06 AM
Sniper
11/15/21 01:11 AM
TJP
11/15/21 01:37 AM
Sniper
11/15/21 01:45 AM
B300 VanDanage
11/15/21 01:40 AM
fourgearsavoy
11/14/21 09:02 PM
Andrewh
11/14/21 10:09 PM
B300 VanDanage
11/14/21 11:42 PM
B300 VanDanage
11/14/21 11:29 PM
B300 VanDanage
11/15/21 04:28 PM
B300 VanDanage
11/16/21 02:00 PM
a12rag
11/16/21 03:31 PM
RustyDuster
11/17/21 05:12 AM
B300 VanDanage
11/17/21 04:59 PM
RustyDuster
11/17/21 08:36 PM
B300 VanDanage
11/17/21 09:34 PM
B300 VanDanage
11/17/21 05:04 PM
B300 VanDanage
11/17/21 11:30 PM
RustyDuster
11/18/21 06:07 AM
B300 VanDanage
11/18/21 03:48 PM
B300 VanDanage
11/18/21 04:04 PM
B300 VanDanage
11/18/21 05:52 PM
B300 VanDanage
11/19/21 02:26 AM
B300 VanDanage
11/19/21 07:39 PM
Cab_Burge
11/19/21 07:51 PM
B300 VanDanage
11/20/21 02:21 PM
Sniper
11/19/21 08:07 PM
a12rag
11/19/21 11:47 PM
B300 VanDanage
11/21/21 02:53 AM
B300 VanDanage
11/20/21 02:44 PM
Sniper
11/20/21 03:16 PM
RustyDuster
11/24/21 04:50 PM
B300 VanDanage
11/28/21 07:47 PM
RustyDuster
11/29/21 05:07 PM
B300 VanDanage
12/06/21 01:52 AM
scratchnfotraction
12/06/21 03:24 PM
B300 VanDanage
12/09/21 03:17 AM
RustyDuster
12/07/21 01:23 AM
B300 VanDanage
12/09/21 08:53 AM
scratchnfotraction
12/09/21 01:50 PM
NITROUSN
12/09/21 03:26 PM
moparx
12/09/21 04:37 PM
B300 VanDanage
12/09/21 06:25 PM
moparx
12/09/21 06:43 PM
B1MAXX
12/09/21 09:36 PM
B300 VanDanage
12/09/21 10:00 PM
poorboy
12/10/21 01:44 AM
340SIX
12/10/21 05:48 AM
B300 VanDanage
12/10/21 05:34 PM
B300 VanDanage
12/10/21 05:33 PM
B300 VanDanage
12/09/21 09:56 PM
B300 VanDanage
12/09/21 06:21 PM
B300 VanDanage
11/20/21 03:15 PM
B300 VanDanage
11/21/21 06:05 AM
67SATisfaction
11/23/21 03:21 AM
B300 VanDanage
11/27/21 07:28 AM
Andrewh
11/27/21 05:30 PM
B300 VanDanage
11/29/21 05:07 PM
B300 VanDanage
11/21/21 03:50 PM
Sniper
11/21/21 04:03 PM
B300 VanDanage
11/21/21 11:08 PM
Sniper
11/21/21 11:12 PM
B300 VanDanage
11/27/21 06:17 AM
RustyDuster
11/24/21 05:56 PM
Cab_Burge
11/21/21 08:23 PM
B300 VanDanage
11/21/21 11:16 PM
B300 VanDanage
12/10/21 08:01 PM
3hundred
12/10/21 08:06 PM
NITROUSN
12/10/21 08:21 PM
Sniper
12/10/21 08:36 PM
B300 VanDanage
12/10/21 10:01 PM
Sniper
12/10/21 10:22 PM
B300 VanDanage
12/10/21 10:33 PM
B300 VanDanage
12/11/21 12:42 AM
Sniper
12/11/21 01:14 AM
poorboy
12/11/21 01:28 AM
B300 VanDanage
12/11/21 04:42 AM
3hundred
12/11/21 04:54 AM
NITROUSN
12/11/21 02:34 PM
B300 VanDanage
12/11/21 06:02 PM
NITROUSN
12/11/21 06:27 PM
B300 VanDanage
12/11/21 06:49 PM
NITROUSN
12/11/21 07:03 PM
B300 VanDanage
12/11/21 07:16 PM
poorboy
12/13/21 12:59 AM
B300 VanDanage
12/13/21 06:17 PM
NITROUSN
12/13/21 06:45 PM
B300 VanDanage
12/14/21 03:36 PM
RustyDuster
12/14/21 02:41 AM
B300 VanDanage
12/14/21 04:12 PM
Sniper
12/14/21 04:51 PM
B300 VanDanage
12/14/21 08:21 PM
poorboy
12/15/21 02:06 AM
B300 VanDanage
12/18/21 01:46 AM
stumpy
12/18/21 01:54 AM
moparx
12/18/21 04:32 PM
poorboy
12/18/21 08:21 PM
B300 VanDanage
12/21/21 07:33 PM
poorboy
12/22/21 02:52 AM
moparx
12/22/21 06:37 PM
RustyDuster
12/22/21 08:25 PM
RustyDuster
12/22/21 08:20 PM
B300 VanDanage
12/25/21 07:53 PM
RustyDuster
12/29/21 01:04 AM
B300 VanDanage
12/29/21 08:25 PM
B300 VanDanage
01/04/22 06:49 PM
B300 VanDanage
01/04/22 07:27 PM
poorboy
01/05/22 03:06 AM
moparx
01/05/22 06:10 PM
poorboy
01/06/22 01:11 AM
B300 VanDanage
01/12/22 01:16 AM
moparx
01/12/22 06:48 PM
B300 VanDanage
01/12/22 07:39 PM
B300 VanDanage
01/08/22 03:56 PM
moparx
01/08/22 06:22 PM
B300 VanDanage
01/09/22 05:54 PM
B300 VanDanage
01/09/22 06:58 PM
poorboy
01/10/22 12:56 AM
moparx
01/10/22 05:01 PM
B300 VanDanage
01/11/22 03:20 AM
B300 VanDanage
01/11/22 03:43 AM
B300 VanDanage
01/12/22 07:46 PM
Sniper
01/12/22 08:01 PM
B300 VanDanage
01/13/22 04:01 AM
3hundred
01/13/22 07:11 AM
B300 VanDanage
01/13/22 04:13 PM
3hundred
01/13/22 04:41 PM
Sniper
01/13/22 06:17 PM
moparx
01/13/22 06:31 PM
B300 VanDanage
01/13/22 07:56 PM
B300 VanDanage
01/13/22 07:48 PM
Sniper
01/13/22 08:37 PM
B300 VanDanage
02/05/22 06:57 PM
A12
02/05/22 07:33 PM
B300 VanDanage
02/05/22 11:13 PM
poorboy
01/13/22 04:17 AM
B300 VanDanage
01/15/22 05:11 PM
B300 VanDanage
02/01/22 03:25 AM
poorboy
02/01/22 03:49 AM
B300 VanDanage
02/01/22 11:18 PM
poorboy
02/02/22 02:36 AM
B300 VanDanage
02/02/22 05:17 PM
poorboy
02/03/22 03:02 AM
B300 VanDanage
02/04/22 05:26 PM
B300 VanDanage
02/04/22 06:18 PM
poorboy
02/05/22 03:30 AM
B300 VanDanage
02/05/22 11:15 PM
340SIX
02/06/22 01:03 AM
B300 VanDanage
02/07/22 01:08 AM
340SIX
02/07/22 02:04 AM
B300 VanDanage
02/07/22 01:28 AM
slantzilla
02/07/22 01:40 AM
B300 VanDanage
02/07/22 04:13 PM
Sniper
02/07/22 01:52 AM
B300 VanDanage
02/07/22 04:17 PM
moparx
02/07/22 06:08 PM
B300 VanDanage
02/07/22 09:32 PM
poorboy
02/08/22 01:21 AM
B300 VanDanage
02/08/22 08:59 PM
B300 VanDanage
02/08/22 09:29 PM
NITROUSN
02/08/22 11:12 PM
moparx
02/09/22 05:46 PM
B300 VanDanage
02/10/22 04:55 PM
moparx
02/10/22 05:39 PM
B300 VanDanage
02/10/22 06:48 PM
moparx
02/11/22 05:46 PM
B300 VanDanage
02/11/22 09:08 PM
B300 VanDanage
02/13/22 04:33 PM
Sniper
02/13/22 04:50 PM
moparx
02/13/22 05:04 PM
B300 VanDanage
02/14/22 01:51 AM
moparx
02/13/22 05:02 PM
B300 VanDanage
02/14/22 01:57 AM
B300 VanDanage
02/21/22 01:50 AM
NITROUSN
02/21/22 03:15 AM
moparx
02/21/22 06:05 PM
poorboy
02/22/22 01:07 AM
B300 VanDanage
02/23/22 05:06 PM
B300 VanDanage
02/23/22 04:55 PM
B300 VanDanage
02/23/22 04:43 PM
B300 VanDanage
02/23/22 05:15 PM
B300 VanDanage
02/23/22 06:09 PM
B300 VanDanage
03/02/22 06:42 PM
Sniper
03/03/22 01:04 AM
B300 VanDanage
03/03/22 04:24 PM
JohnRR
03/04/22 02:16 AM
BloFish
03/05/22 03:46 AM
poorboy
03/03/22 01:06 AM
B300 VanDanage
03/03/22 05:16 PM
