Originally Posted by B300 VanDanage
Ok so one of the remaining two connecters gets a "switched" 12v wire and the other to the choke resistor...
What's a "switched" 12v?? Is that just a hot wire that's only hot when the ignition is on?
Correct, switched mean it only has power when the ignition switch is on.
