Quote: The Hemi 6 can't do what the Grid can do. Its just that simple!
Well, then you're stuck with Jesel set up with two belt driven distributors and multiple ignition systems. BES did a custom Dual Belt Driven Distributor for one of their Engine Masters Engines, that they made a cam drive adapter that poked thru a modified stock cover and they used two totally independent ICE Ignition Systems and Coils....one for each distributor. And that's if you want to run both spark plugs. Not sure how much or if there would be a loss of power with only one plug.
