Quote: It does not take any different wiring to fire both plugs than it does to fire one. The same two primarie wires that fire the individual coil also fire the dual plug coil and since one coil fires two plugs there is nothing else to do.
I would bet you would need a bunch of different sensors though
I'm thinking the most difficult would be the toner ring and cam position sensor. The rest IMO would be easy. So if what I am saying is correct then this is possible or am I out in left field.
