So how does the Eagle head compare to the 6.1? Will either work with the drag pak intake? Sounds like the Eagle head is cheaper than the 6.1 but is it the better way to go? And I guess another question is the Apache head an option? Looking at flow numbers on the Apache head I would say that making more than 650 could be more likely than not. I guess I can always slow the thing down
