Quote: This stuff with the Gen III is really frustrating, confusing, discouraging, expensive, time consuming, labor intensive, expensive, frustrating, and did I mention expensive....I think I'm going to go CrAzY before I get anyting done.. ....nothing like a learning experience..
Care to elaborate on your issues?
Mostly just frustration from no experience on these engines...get a 'game plan' worked out in my head/on paper,,then start trying to find parts,,find out I can get better, quicker, results buying complete components. Probably just started out with the wrong engine(5.7), should have started with a 6.1...problem being, couldn't find one. This was supposed to be a conservativly priced experiment with the Gen III Hemi, to be used as a 'test' engine, but has turned into a costly 'primary' engine.
If you like drag racing, support your local track.
