Quote: The way the new Hemi's are designed, you really don't need those clips or spacer's. The pushrod angle will keep the rocker arm tight to the rockershaft holdown. When you want to spin these new Hemi's up and control oiling...? That's another story.
So what is a safe rpm without oiling mode? 6500?
Your safe at 6500 rpm. Above 7000 rpm is when you get into the pucker factor.
