Quote: The way the new Hemi's are designed, you really don't need those clips or spacer's. The pushrod angle will keep the rocker arm tight to the rockershaft holdown. When you want to spin these new Hemi's up and control oiling...? That's another story.
So what is a safe rpm without oiling mode? 6500?
Your safe at 6500 rpm. Above 7000 rpm is when you get into the pucker factor.
So my previous post about the oiling issue, am i close in thinking that at a higher rpm the oil is moving so fast that it has a hard time making the 90 turn at the mains? This is why the fist and last bearing are alright but the middle ones strave for oil. Or am I out in left field. BTW thanks for the info
