Anybody had any trouble getting cam bearings to fit camshaft..? I don't mean the obvious hassle of installing/removing cam bearings, just the clearance between cam journal and bearing. I am using Clevite #SH-1990S and they are tight right out of the box. The cam journals are at factory specs and just a bit smaller... Is there another cam bearing others are using??
If you like drag racing, support your local track.
