Very nice looking setup.
If I could ask were did you get your alternator and brakets from?
Cheers
g408
Alternator is a 93MM Denso that is sold by Powermaster and Summit carries them. Don't let the 93 MM confuse you. The Mounting bracket is made for this alternator that has 138MM center to center measurment on the mounting lugs (you can see this on the link provided). 93MM is the case size.
http://www.powermastermotorsports.com/denso_alternators.html
Mine is the 8162.
Ron.
Thanks Ron for the info has been very helpfull.
Cheers
gg408
