Are you going to have it dynoed before installing it?
I would never rely on a Dyno to get my HP. I have only one way of doing it. Vehicle weight VS MPH. I have never dynoed an Engine and I probably never will.
Of course you might want to look at 60 ft to see if chassis efficiency is there etc. But that will not affect MPH much so you can pretty much use MPH. What I am saying is, in a properly set up car the MPH VS Weight will tell you.
I would only use a SINGLE dyno, to compare two engines, or to compare different mods on a single engine.
SRT DEMON ONE SEAT
