Very nice looking setup.
If I could ask were did you get your alternator and brakets from?
Cheers
g408
I ordered that bracket from KRC Power. I am not using it as designed though. It is designed to have the alternator on the front side of the bracket to lineup with a "drive pulley" that would be FRONT of the water pump shaft.
So, I did modify it and if you look close you can see what I did. Copy and paste the pics on your PC and then you can zoom in. The lower front side is MILLED to clear the fan belt, the front side right where the water pump pully is had to be milled slightly to clear the water pump pulley. I just plunge cut with an end mill in a drill press a bunch of times until the metal I need is all removed.
There is about a .250 spacer behind the bracket for alignment purposes. The water pump pulley is a mid to late sixties small block single groove pulley and I think if you took the spacer out it may align with the early 70's small block water pump pulley.
Here is a link and a pic from another angle so you can see what is going on.
Ron.
http://www.krcpower.com/catalog_i6511685.html?catId=353136
SRT DEMON ONE SEAT
