Yes I like the Hoosier DOT Radials over the Quick Time Pro's and I like the QTP's over the MT ET Streets. I have never tried the MT ET Street radials but I do not consider that tire a good choice for a track that does not have excellent prep.
I consider the Hoosier DOT Radials to be basically a Drag Radial slick with a couple Grooves in it. Just like the QTP's are.
Pinned down: I put the rear segment clamps back on the Tri City Launchers and I cranked up the front Shock rebound damping setting. If that does not do it I will install bigger upper control arm bumpers to limit front end travel/rise.
SRT DEMON ONE SEAT
