Quote: The real way to tell if it is a stripe delete would be the GTS letters on the front fenders! All 69 stripe delete cars had these, if not, then it could have been a stripe that was removed at the dealer,
Beat me too it .
Mike you know I had to throw that out there about the tag
On a side note I can't find those 69 GTS emblems anymore , are they still repopped ?
I have several of the repops, I am sure they are still available, I will check into it.
So do you think it might be a legit stripe delete Dart and if I put a tail stripe on it do I have to remove the GTS callouts and give them to John
I'll take whatever you want to give , they have the right amount of PATINA to match the orange peel in my paint job .
