Quote: Did they produce any Barracudas at Lynch Rd???
What he said , since they did NOT build A bodies at Lynch Rd. that is NOT a M code A body block ...
Which explains why it looked TOO GOOD , that was done in a milling main of some sort.
The block that I bought was a 9B vin and found in the same general area the car had been all it's life . the car from Jim's current block I have not been able to find as of yet.
John, if the engine that you're saying looked "TOO GOOD" is the engine photo I posted; THAT'S A 9B Hamtrmck ENGINE....see the next photo I posted of the VIN two post later.
