Quote: thanks, any difference on the top tank other than the part number?
Quote: Rhinodart said :
Top hose location is the same, bottom hose is not.
BESIDE the part number and THE HOSE LOCATION? (big font, little font, use Chrysler blah, blah, blah )
I forget that you suffer from A.D.S. , thinking maybe someone can make a tag for you to solder over the wrong number if you can scare up the right bottom tank ?
I thought that the round top 22" was repopped ?
Not by Bob at Glen-Ray...Bob and I talked about that a few times and I'm sure that I'm not the only one that has talked to Bob about a 22" round top radiator, am I Bob I think there are way more different 22" rt radiators that makes it tough to single out the ones with good enough demand to make it worthwhile to repo one versus another?
