Dave you need to re-read what you wrote... " It tells EVERYTHING and MUCH MORE than the Broadcast Sheet"
I agree it tells you a lot more but the window sticker will not tell you EVERYTHING and more. It will tell you a lot of info that is not on the BCS as you mentioned but it does not incude all the info that is found on a BCS....
Yes you can find out the correct carb numbers in other manuals and such but how can you prove your car was BUILT with the carb a manual says? Only the BCS can tell you that info and more, a lot more.
