Quote: I don't know if it's even possible, buuuuuut... would it be possible to offer (even if a special order), carpet without the padding? (For goofs like me that want to shave the original jute padding and reuse it on the new carpet ) Maybe that's not feasible with your contour molding... I don't know at what point the pad is glued on.
Will you be using ECS as your exclusive distributor? Put me down as interested in distributing if you decide you need multiple locations.
I'm with Rick on this one, the original padding can often times be saved and comes off pretty easily intact if you are careful. Even if not re-usable most are still good enough to make a pattern from which can be transferred onto a piece of (appropriate thickness) foam carpet backing that could be glued on to the new carpet set.
Please put my hat in the ring for a West Coast vendor.
*BTW
Quote: Re: FINALLY! FACTORY EXACT AUTO CARPET!!!
You might want to tone down the "Exact" part of your description, I'm sure these will beat anything that's currently on the market, but calling what has been shown so far "Factory Exact" is a bit of an exageration IMO
