It would be an interesting read if we could have just the real engine builders only have a so to speak engine build off against each other.
They get to choose their engine of choice be it Mopar,ford or chevy.
No nos, blowers,superchargers or prochargers all motor!
And if you name is not on the list at the start you can not post or join in no matter how good you are once it is started!
PS not that I don't find this post amusing as it is,but would not mind learning a few things.
PS,PS It would be nice if each included a build specs sheet showing all clearances and tolerances,like you would get if you brought or had an engine built!
Yaaaaa right. And if you rub this magic tea pot I will give you three more wishes. Some build secretes are SECRETE.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
