The point is it could be done but the blocks are over priced and hard to get and the options aren't there. It's an end user problem.
So who is at fault ? If the Mopar guys have bought up every X-block, R-block, Megablock that has been produced...and bought Every Crate Hemi that has been built.....how on earth can anyone blame them ????
OK I'm gonna try this one more time, just for sport. If the supplier produces 60 blocks, and the consumers need 70+ blocks, how many blocks does the supplier need to make to keep up with demand? And the bore needs to be 4.700 or bigger, and the stroke needs to be 5.5" or bigger, and the current block and cyl head design only allows for 4.560 bore by 5" stroke, what needs to be done to supply little Johnny a block? Can you say aftermarket bow tie? Sure you can.
Ok....Earth to lil'Tommy, you're in the wrong forum....
and please have someone else, build, install, tune, and drive it....no sense blowing up more stuff and putting others in harms way....
Dude... You need to go away.. Maybe go hang with Doc Fiberglass..
Chris.. your wasting your time... he is like a fly..
eats s#$t and bothers people
