Quote: Thanks Jim. I am still learning as I go so I have no idea as to the options that were available on these cars. Do you know if Chrysler ever used that odd washer bottle screw for anything other than the A Body cars?
Has this "special" washer reservoir ground wire screw been found in that same position on other A-bodies of similar provenance?
