Check out the "leftovers" that we found UNDER the carpet. The red cap probably sealed one of the inlet/outlet tubes for the heater core. You can see where the imprint remained in the jute pad after all those years. The other photo shows a carpet tag from a vendor that I did not know supplied carpeting to Chrysler. It is the third supplier that I have documented in all of our research.
