Quote: (Paint coverage, primer coverage, dip line, package tray area bare metal, etc…..)
That's the stuff I'm interested... I would like to see if there's bare metal under the rear tray area in the trunk etc....and if so is it rusted?....by the look of the rest of the pictures of this car look, I would expect these areas to be very well preserved with no signs of surface discolouration or rust. HOWEVER...if these areas are rusted and not 100% clean bare metal (with the exception of overspray) I expect an indepth description of how you bring these areas back to the "NEW" appearance that you're after, including which type of chemicals/cleaners are used etc...
I'm glad I'm not doing it, only reading about it
If I understand your mission fully, then I would say this project will be way more involved then most people can even imagine.
