there is a difference between trying to convince someone and explaining how you do it. so you are trying to convince someone every time you post? ok show me 1 post where I said it's wrong? and I haven't posted on this subject in a long time, and the only reason I did is because the op was so far off on his calculations. I knew I would get hammered by the normal crowd it happens every time.
