Originally Posted By Monte_Smith
Originally Posted By NITROUSN
Monte on this pic the shaft is out of phase and the red dust by the rear cap indicates a bad joint.
So is your suggestion to point the pinion straight ahead, to "equal" the planes? Can you imagine the angle the shaft will be on? Sorry, believe I will PASS on the fix...........And the red you see is not dust, but red colored dust seals on the joint. I have had this thing a LONG time. I believe if it had a bad joint, I would know it........Plus, this is how it came from the factory
Monte.. he is referring to the location of the U-joint caps
but if I recall that spline section is a one location only so
you cant change it... but normally the caps are square to each
other
wave
