Yes I know this topic has been run into the ground but I'm a dummy and I want to get this right the first time. I have 4 degree down on the tail I have 7 degree down on the pinion This is a cal trac setup in an a body anywhere from 3100 to 3300 pounds. Those reading put me at 3 degrees Is this ok for a strip car?
