Type: 1968 440
Displacement: 446"
Compression ratio: 11:1
Head type: Stock 906
Cam type: Mopar
Specs: .590" solid
LSA: n/a
Intake manifold: MI single plane
Exhaust: 2" primary Hooker fenderwells, 3" 2-chamber flowmasters with turnouts
Carb type: Holley double pumper
Jetting: Front: 80 jets Rear: 80 jets
Total timing: 44 degrees
Trans type: 727 Auto
Torque Converter size: 9.5"
Stall behind your motor: 3600-3800
Gear ratios: stock
Rearend ratio: 4.30
Tire size: 28" x 11.5
Vehicle weight: 3290 with 190 lb driver
Horsepower: N/A
Torque: N/A
E.T. 11.37 1/4, 7.10 1/8
MPH (as above): 115, 96
Comments: Why is it so hard to get a 1968 Dart under 3000 lb?
