Displacement: 440
Compression ratio: 7.8 to 1
Head type: Stock 452 castings
Cam type: MP P4120237
Specs:292 adv .509 lift 108 Lc installed at 108
Intake manifold: Performer RPM
Exhaust: 1-7/8 primary flowtech
Carb type: holley 800 dp 72 primary 78 secondary, choke plate removed
Base timing:
Total timing: 38 degrees locked in
Power adder: Aluminum water pump and housing?
Type: NA
Blower impeller speed: NA
Nitrous jet combo: NA
Amount of positive manifold pressure/nitrous hit:
Intercooler: NA
Timing pulled if any: NA
Trans type: 727 with T/A manual VB
Torque Converter size: 10” gator
Stall behind your motor: 3500 flash
Gear ratios: stock
Rearend ratio: 4.30
Tire size: 9-29.5
Vehicle weight: 3580 race ready
Horsepower Unknown
Torque Unknown
E.T. (specify 1/8th, 1/4): 12.77 1/4 mile, 1.72 best 60 ft.
MPH (as above): 105.39 MPH
Comments: Stock 80,000 mile motor out of 77 grand fury cop car. Over 500 passes, cant kill it! It shouldn’t run this well, but it does.
