Type LA
Displacement 360 +.030
Pistons K.B. #107 flat top
Rods stock reconditoned A.R.P. bolts
Compression 9.7 to 1
Head Type stock 360 J 1.88 int./1.60 ex.
Flow # n/a
Cam Type HYD.
Specs 508 lift 292 dur. Mopar
Installed at 108
Intake Manifold Edlebrock TM5
Exaust 1 5/8 headers 3x18 collectors
Carb type Holley DP
Size 750
Jetting 80 pri 82 sec
Base timing 15 deg
Total timing 35 deg
Power adder none
Trans type 727 reverse patern man. valve body
Gear ratios stock
Converter Coan 10 inch 3500.
Rear end ratio 3.91 8 3/4
Tire size 28x10
Vehecle weight 3350 with driver
Horsepower aprox. 375 at rear wheels
Torque na
E.T 1.63 60FT. 12.04 1/4 MILE
MPH. 112
This car is completely street legal and is street driven regularly.
