Type: LA block
Displacement: 360"
Compression ratio: Stock
Head type: Stock w/ sodium valves
Flow #s : N/A
Cam type: Stock RV cam
Specs: N/A
LSA: Stock
Installed at: Stock
Intake manifold: Weiand X-celerator
Exhaust: Stock manifolds, 2.5" dual exhaust dumping out ahead of rear wheels
Carb type: Edelbrock Performer
Jetting: Haven't done it yet
Base timing: Haven't done it yet
Total timing: Haven't done it yet
Trans type: 727 Heavy duty
Torque Converter size: Stock
Stall behind your motor: Stock
Gear ratios: Stock
Rearend ratio: 2:76
Tire size: Front 225/50R15, Rear 225/60R15
Vehicle weight: 3150
Horsepower: N/A
Torque: N/A
E.T. (1/4) N/A
MPH (as above): N/A
Comments: Okay, so it's not very exciting to read about (lots of "stock" in there) but I'm proud of her. I've also got an electric fan and electric fuel pump to add to my short list of mods. Should be firing her up sometime in the next week, then I'll be able to say more. This is a great idea!
