Type: RB block
Displacement: 446"
Compression ratio: 10.25:1
Head type: stock Edlebrock
Flow #s : N/A
Cam type: MP 484
Specs: 284 duration and .484 lift
LSA: 110
Installed at: 108
Intake manifold: Edlebrock, Aluminum 6 pack
Exhaust: Hooker Super Comps 1 7\8" primaries, 3" Collectors full 3" exhaust and tailpipes
Carb type: Holley Six Pack, Quick Fuel Metering Plates
Jetting: 84 Front, 70 Center, 84 Rear
Base timing: 15 degrees BTDC
Total timing: 50 degrees BTDC @ 2500 rpm, vacuum advance
Trans type: 727 Auto, Reverse Manual VB
Torque Converter size: 10" Dacco
Stall behind your motor: 2500-2600
Gear ratios: stock
Rearend ratio: 3:91
Tire size: 28"X10.50"X15"
Vehicle weight: N/A stock
Horsepower: N/A
Torque: N/A
E.T. (1/4) 12.11
MPH (as above): 112.69 mph
Comments: Engine and suspension built by Doug Dick (410-320-6305)
This is a heavy street car that can run low 12s and then take the family out for ice cream afterwards.
