Type: LA 360, 73 casting
Displacement: 365" (360+.030)
Compression ratio: 9.2:1 (KB107s)
Head type: "X" casting, 72cc chambers
Flow #s (if any): no idea. Intake runners ported lighlty, exhaust runners ported a bunch
Cam type: solid, Crower #31321
Specs: 294/298 adv dur, 243/245 dur @ 0.050, .521/.528 gross valve lift, .022/.024 lash
LSA: 112
Installed at: 108
Intake manifold: Performer RPM
Exhaust: 1 5/8" primary, 2 1/2 pipe to axle, Hooker Aerochamber mufflers
Carb type: Mighty Demon
Jetting: 73/81 jets, 6.5 PV, 1/2 4-hole plastic carb spacer
Base timing: 20 degrees BTDC
Total timing: 33 degrees BTDC @ 2600 rpm
Power adder: none
Type:
Blower impeller speed:
Nitrous jet combo:
Amount of positive manifold pressure/nitrous hit:
Intercooler: Y/N, eff. #s if any
Timing pulled if any:
Trans type: 904
Torque Converter size: 11 MP 175K
Stall behind your motor: 2700 against brakes, 3000-3200 flash
Gear ratios: stock
Rearend ratio: 3.55
Tire size: G60-15
Vehicle weight: 3150 (72 Duster), without me, with full tank of gas, full spare, all steel.
Horsepower (if dyno'd, specify FWHP or WHP): ?
Torque (as above): ?
E.T. (specify 1/8th, 1/4): dont know yet
MPH (as above):
Comments: Fresh motor with 2000 miles. Nice lumpy idle and very drivable. Smooth off-idle transition, even with 3.55s. Pulls 12-13 vacuum at 800 RPM. The motor is just as happy at 1500 RPM as it is at 6000+. 12-13MPG, but I didn't build it for fuel milage.
Cant wait to get this thing to the track, hope to go low 13s at least.
