When I went back together I snugged the caps & then loosened them to where they were just BARELY tight & then set the back lash & preload, then torque the caps & then recheck the BL, the preload was set by both spanners touching the race with no play & then turn the left adjuster one click, ie one hole, this was all done while setting the BL
That is how much preload it had when I took it apart. about 5k miles on it.so the bearings are broke in,
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
