Just to get a starting point I put the car up on the scales. Obviously the car isn't complete so I added weight to estimate where I'd end up. I put a battery in the trunk as well as the fuel pumps and then added 35 lbs of ballast for the fuel. I put weight in the driver seat for a driver and I put the starter, water pump and stuff like that in a box on the front fender. The radiator is in place but it is dry. The car is missing a driveshaft and the torque convertor so I'm light there.
Anyway it comes out to 2800 lbs as is so I'm thinking I should be able to go down the track at less than 3000 lbs. I need to add wiring and plumbing and a front windshield so I know I'm light, but I don't think I'm more than 200 lbs light.
Interesting thing was the weight distribution. Looks almost perfectly square front to back and side to side. I'll keep an eye on the corner weights as I build the car. Love to see it go down the track with a 50/50 weight distribution. That should help it hook......
