Thanks. I put the finishing touches on the front sheet metal and I was able to finally figure out the exhaust tips. Everything takes so long to do on these projects it is hard to stay motivated. The exhaust tip install took several weeks by itself. I tried a few different tips then once I selected these I had to cut away the existing brackets and fabricate new ones. Seems like it would be a 30 minute job to install exhaust tips but not when everything is custom. Same with the front spoiler and the grill support. Lots of fab work required since the core support was modified and relocated. Everything else got shoved around by custom core support.
