Here is a better shot of the front chassis work showing the under fender bracing as well as the new core support.
Awesome work as always Andy. Just a thought, you may want to add that fresh air vent back to the battery box side if you are still going to run the battery up front. It will help to keep the battery temp down a little with summer street driving.
