I put about 1/2 turn of preload in it and took it for a drive. It doesn't bang on the 1-2 shift but it bangs hard on the 2-3 shift. Not sure why that is. I did try a 2-3 shift while I was on the throttle and it didn't bang so perhaps it just depends on how the suspension is loaded. I'll call Calvert next week and chat with them to see what they say. The car seems to hook and go straight on the street although I haven't hit it with more than 1/2 throttle so far.
I did get the oil temp, trans temp, driveshaft speed and fuel gauge hooked up and working on the digital dash. I still need to program the dash with turn signal indicators and then I'll be pretty close to finished. I also added a second O2 sensor so now I have one in both head pipes.
I'm probably going to buy the Holley G force sensor and plug that into the computer. Then I can data log G forces.
