If you are running cal tracs with the solid bushings in the front you will probably find you don't need the front sway bar. I was very surprised at how much the solid spring eye bushings killed body roll when I put them on ages ago. My car doesn't have much body roll with cal-tac monos, /6 bars, and no sway bars. On drag week this year we went through lots and lots of sharp and curvy mountain roads. My car sits at about 4000-4100lbs on the road for drag week(gear plus passenger) and handling was of very little concern, I think the spool and skinny fronts run out of talent before body roll can become an issue. Just an FYI if you want to save the weight.
I hadn't thought of that. I'll keep on eye on how the rear bushings make the car feel.
