Are you installing a rear sway bar that is proportional to the new front sway bar?
Motor mounts? No motor plate?
I do not intend to add a rear sway bar. Yes on the motor mounts. I'm pretty sure that I'm going to switch over to the DC type K frame with spool mounts and not use the motor plate. I have some other things that I want to do in the engine compartment that won't work with a motor plate so I'm making the switch.
