Ran the engine on the dyno today. This is a 512 inch low deck with MCH ported Mopar heads and a Holley EFI setup. It is a 10:1 pump gas engine with a hyd roller cam. The engine made 600 hp at 5900 rpm and 580 torque at 5800 rpm. The torque curve has a bit of dip in it since the torque at 3200 rpm is 571. So saying the torque peak is at 5800 is true, but a little misleading. Not sure why there is a dip in the torque curve, something isn't happy between the cam, intake and exhaust system I suppose. But 600 hp should be enough to put the car in the low 10's if it hooks up so that is fine with me. I didn't prepare the car to run faster than that anyway.
