Koni 80-1538 is the front shock for A,B and E body cars. If you search for a '70 Cuda the number will come up but if you search for a 1965 Dodge Coronet it won't find anything. I like the Koni shocks since they are adjustable. You just collapse them and then turn them a little bit and the shock will drop into adjustable mode and then you can make them firm or soft. I usually set them up on the firm side of the middle of the range.
