Hey there! First off, I just want to say thank you for the build thread. Very impressive fabrication skills. I do have a question though, I was wondering what thickness metal you use for body panel repair, and metal thickness for the sheet metal work your doing? Thanks, looking foreword to watching this build.
Justin
Justin,
All of the body panels I have matched the same 20 gauge steel that was used originally. For most of the structural components that I added to the bottom of the car I used 14 gauge to 1/8" steel and some 3/16". Thanks for following along!
Pat
