Disassembled both doors so I can send out the vent window and door handles for re-chroming. Here are a few picture of the left doors hardware cleaned and painted along with the right doors hardware as it came out.
I remembered from my last 68 charger that reproduction the tail light gaskets didn’t fit well. This time I was able to remove the original gasket without much damage and used an upholstery steamer to expand the foam. Then I sprayed a few coats of Plasti-Dip to fill in any damage. They should work like new!
Pat
