Cleaned and painted the inside of the cowl and painted inside firewall along with the bottom of the Cowl. I use a paint that looks like the color of steel as this will make it a little brighter under the dash when working on it. With the car on the rotisserie it was very easy to use a self leveling seem sealer fill the original firewall panel seams. Thanks Pat
