Finished up the tail light wiring, subwoofer & speakers, and started on the power window wiring. Found a nice set of JL 5 x 7 speakers. They fit the factory speaker holes in the package tray without cutting. With all four windows using a special switch that utilizes the original crank handle I decided to put the separate 4 window controller switch assembly under the dash so the car will look as though it has manual windows (like the movie car;-)
