Originally Posted by Keepat
Originally Posted by NITROUSN
Very nice. Any pics on the antenna motor mounting?
Hard to see in the picture but I had to make a small L bracket to hold the motor
[Linked Image]image post
What can I say, wow wow wow, what a top notch build, I adored every bit of the 45 pages.
I'm just about to install a power antenna on my 69 charger that doesn't even have a fender hole for the antenna. May I ask if this is the antenna you used? Would you remember what fender angle adapter you needed?
https://www.retromanufacturing.com/...omatic-power-antenna?variant=31333675406
I'm thinking of using this one https://www.retromanufacturing.com/collections/antennas/products/fully-automatic-mini-power-antenna
Thanks for any help!
