I started on the roof of the car by using paint stripper to remove the vinyl top glue, paint, and primer. Then I used a 6” DA sander to remove any leftover glue and paint. As with most vinyl top I was left with some rust and pitting to treat and repair. I coated the roof with a gel rust dissolver and covered the roof with plastic to keep the gel from evaporating. After about 8 hours I removed the plastic and rust dissolver then neutralize the roof with water, and paint prep. One last sanding with 80 grit on the DA sander, a wipe down with Final Klean and 2 coats of epoxy primer. Next I’ll will skim-coat the roof, sand and more epoxy primer. Thanks Pat
