Fabricated an aluminum K member dolly as I will be installing and removing the motor and trans a lot over the next few week to fit the tunnel to the transmission.
I will have a scissor jack at the trans end to help adjust the fit in the car.
With K member dolly made I move the motor from the house to the Hot Rod shop. This is as close as the motor has gotten to the charger and it is about to get closer! Thanks Pat
