I Installed the passenger side rear window and trim. The AMD quarter glass was a heavy 1/16” taller on the rear 12 inches compared to the original. So I had to sand it down with a DA sander to get the best fit. All of the AMD glass has a rough finish on edge so I use the DA sander starting with 60 grit and working my way to 180 to polished edges that shows. Thanks Pat
