Quote: Build looks awesome. What is your procedure for metal finishing your welds down on the patch work? It looks fantastic!
I'm not sure I have any secret techniques that you can't already find online. The most important thing to remember is taking your time and don't let the panel get too hot. As I stitch weld I'd like to grind down the small welds close to the panel surface as I go Instead of grinding all the welds down when you're done. This helps keep the panel temperature low and It also helps when you're connecting the stitch welds as the panel thickness is more consistent with your amp setting on the welder. Thanks Pat
